Hi guys. I'm new to the Wrangler community and could not find info on theta stock radios. I gave up a fully loaded luxury SUV with a tech package. So there are a few things I'm missing. Mainly a Bluetooth phone interface. My Jeep has a bares bones stock radio. Is like to swap to a factory radio with Bluetooth and XM built it. Can someone tell me
If the Bluetooth mic is built Into the radio or if I'll Need to run a separate mic and change the harness. Also where is everyone installing your satellite antennas? Thanks in advance.
Welcome to the forum. There are plenty of options available. You can try to round up an RHR unit. Bluetooth is built-in. The NAv antenna mounts to the frame above the radio. RHB unit would need the bluetooth module separately. Both would require a microphone. The wire comes long enough to run it to the A pillar right below the visor mount.
These are stock Mopar replacement units. The Wranglers come with them as add-ons.
You could go aftermarket. Plenty of stuff out there. There ae camps for both options here on the forum. You will probably hear from both, soon.
Bob
