Hey Guys, I have an '05 LJ and I can't get the doors to lift out. They open and close cleanly, but won't lift up. I even tried to use a jack and 2X4 to push up, but that didn't work.
Any ideas?
Thanks
when I tried to lift my doors first time, it wasn't going well. Then i sprayed WD-40 and in 10 minutes they were going like butter.
I'd say try to spray WD-40 or pb blaster spray before you try anything else.
Hey Guys, I have an '05 LJ and I can't get the doors to lift out. They open and close cleanly, but won't lift up. I even tried to use a jack and 2X4 to push up, but that didn't work. Any ideas? Thanks
Use some lube as stated. When using jack and 2x4 move the door back and fourth watch hinge area you should see it move up slowly. Be careful start with low pressure on bottom of door with Jack. I'm also assuming you removed nuts from the pins.
