1 - 11 of 11 Posts
1990 4.2 the temp gauge wasn't working when I purchased it so I checked the sending unit to see it it was plugged in. Nope. So I plugged it in and it worked for a day. I replaced thermostat thermo housing and coolant sending unit. It still doesn't work. I pulled the dash apart tonight and couldn't see anything that looked messes up. Am I forgetting something? What else can I do? The gauge flickers just a tad when I turn the key onto the "on" position.
where was the "sending unit" located on the engine? front or rear of engine?
Unplug the sending unit on the rear of the head on the drivers side right next to the valve cover and plug a grounded test light into the wire and turn the key on, if the temp gauge shoots up then you know the gauge and the wiring is good, which means it would be the temp sending unit. Its $10 at autozone.
In my first post it states that I have already replaced it
have you replaced the coolant temp sensor. my guage will jump to 100 but then never move. that was my problem. And its sixteen dollars at Auto Zone i checked yesterday while working there
Not yet. I will replace that.
just replaced my temp sensor. Gauge still not working. Guess i will mount a new gauge. Let me know if you figure it out:banghead:
1 - 11 of 11 Posts
