I have a 2010 JKUS with stock 255/70R18 tires.
I am looking at installing a 3.5" lift kit and go with 35" tires, maybe 37" someday. This is not a DD, but a pull behind the RV travel to off-road sites and get around vehicle. Due to the backspacing of the stock rims and the 18" size I was really thinking I should get new rims and go smaller. I was thinking a 17" rim.
What are the pros and cons of staying at 18" vs a smaller rim size? I have seen in doing some pricing that 18" rims do have more cost in the tires. Am I correct or am I am missing something.
There is a broader selection and better pricing on tires and wheels based off of the 17". I do like the look of a 18" wheel on a 35 or 37" tire, but the price gouges my wallet. Too much bigger wheel and it just turns into a grocery getter in my humble opinion.
You on the right track going to 17s
Tire & Wheel Specialists
As Shadowmaker pointed out, the selection is broader in 17-inch and is more economical when compared to 18" of equal size.
I wouldn't say there are any con's per se but bear in mind that moving from a 32" tall tire to a 35" or 37" will affect handling. Taller sidewall height translates into more "roll" so steering response will be reduced.
Since I'm not planning to use this as a DD or for performance handling that should not be an issue.
Will having taller side walls benefit off road handling when aired down?
Is a 17" the best option or should a 16" be considered?
Sent from my XT1650 using Tapatalk
I'm not sure a 16" rim fits over the brakes. I believe I've read elsewhere 17" is the minimum.
Vote 17's all day for tire option fro your application, wheel options, added sidewall, better look than 18's with larger tire sizes such as 35/37's, better air down performance and stability and so on....
