1 - 13 of 13 Posts
I made a mistake and let my son drive my 2017 Rubicon two door for a day . He is needing a new DD he is only 3 miles from his job and his Ford Ranger a 2009 is about shot (149,000 miles ) now he is looking at a new Wrangler Sport two door with almost zero options . He will order it with only power steering - power brakes and AC . It will show up with 3:21 gears and a 6 speed manual trans . My Rubicon has 4:10 gears and 6 speed and he loved it . Just how bad will it be with this rearing he will used this also for hunting trips and zero mod,s .
3:21 is pretty anemic IMO. But if he's not doing anything will it except hunting (im assuming dirt roads) and driving around town, it should be fine. I wouldn't go crazy with it though. If he can swing it, get the tow package and the 3:73 gears and he'd be in a better spot. Just my .02.
If you keep it stock, the 3.21s are fine. My '17 JKU had 3.21s on it and it was fine until I upgraded everything and moved to 4.88s.
You mention hes ordering a new wrangler, wouldn't it be JL not a JK? As far as I know they stopped making the JK in March 2018. Maybe I'm wrong, at any rate 3.21 on stock 2 door/6spd should be fine though I would suggest he try to test drive one before ordering.
Discussion Starter #7
New JL Sport comes with 3.45 standard gear ratio no more 3.21
I did not know that I guess that (3:45) would make it better ?
I posted in the JK part because I thought I would get more answers to this question . THANK YOU .
It will be far cheaper to order the Jeep with the gears you need vs regearing after the fact. Think you can order 4.10s pretty cheap.
IMO JK 3.21 AT problem is in transmission programming and not axle ratio.
shifting points are out of whack.
when I drive it in manual mode is ok. I would probably be much happier with 3.21 MT 6 speed.
3.45 with MT as a DD should be perfect
Again we are not talking about 40" wheels and rock crawling just street driving and some light to medium offroading.
I don't believe there are any options on differential gearing. If you buy a Rubicon, you get 4.10s, everything else has 3.45s with no upgrade options from the factory. PB and PS are standard equipment now. While you can order a Wrangler without A/C, I doubt any dealer outside of Alaska would have one on their lot. If you ordered said Wranger, you would probably have to make a hefty down payment before they ordered it, for if you backed out, they would be stuck with an almost unsaleable vehicle.
We were down in Montgomery, Alabama in June, and test drove a couple JL's.
Dealer had a 2 door sport on the lot with no AC... In Montgomery, Alabama... In June... No AC... :facepalm:
My guess it is still on their lot, unless they gave it away....
1 - 13 of 13 Posts
