And bigger sidewalls in a comparably sized tire, resulting in better air down ability and a more comfortable ride. Also, the stock wheels have high backspacing such that the tires he's considering will not fit--he needs new wheels or spacers. :thumb:there is no diff in ground clearance with wheels...only bigger tires solve that....advantage of 15" rims is price, availability, weight (mpg), and looks ;]
Check!Wheel size has nothing to do with ground clearance. Only the tire diameter.
Checkthere is no diff in ground clearance with wheels...only bigger tires solve that....advantage of 15" rims is price, availability, weight (mpg), and looks ;]
Check!And bigger sidewalls in a comparably sized tire, resulting in better air down ability and a more comfortable ride. Also, the stock wheels have high backspacing such that the tires he's considering will not fit--he needs new wheels or spacers. :thumb:
For tires, there's nothing lighter than a DuraTrac that I'm aware of in the 33x12.5R15 size. For wheels, there are comparably light 15" alloys. I did 15" Black Rock D-Windows, which are about the same weight (see here). Here's a series of links to 15" alloys that will fit. I'd expect they'd all be around 20 lbs.So, is there a lighter setup of 33's (reasonably priced) other then the MB72/Dtac setup?
As I get closer to buying time I'll have to keep comparing.For tires, there's nothing lighter than a DuraTrac that I'm aware of in the 33x12.5R15 size. For wheels, there are comparably light 15" alloys. I did 15" Black Rock D-Windows, which are about the same weight (see here). Here's a series of links to 15" alloys that will fit. I'd expect they'd all be around 20 lbs.
I've been following your discussion of 15" alloy wheels and 33" duratracs with great interest.For tires, there's nothing lighter than a DuraTrac that I'm aware of in the 33x12.5R15 size. For wheels, there are comparably light 15" alloys. I did 15" Black Rock D-Windows, which are about the same weight (see here). Here's a series of links to 15" alloys that will fit. I'd expect they'd all be around 20 lbs.
For the tailgate? Yes. Here's a pic of my tailgate now with the stock bumpstops:[W]ill I need to get new bump stops?
Very interesting Bill . . . that article could use it's own thread and follow up discussion . . . :thumb:I've been following your discussion of 15" alloy wheels and 33" duratracs with great interest.
After reading about the advantages of thinner tires for the type of conditions that I usually encounter in this article:
Expeditions West: Tire Selection for Expedition Travel
.... I'm also considering procomp 8170 series, alloys in 15" size (16 lbs.), and BFG MT KM2s in 33x10.5x15 for the narrower tread, easier fit w/o lift (?) and light weight (49lbs.) A total of 10 lbs/tire less than stock (!)
Lots of thinking to do about the thinner tread though. Kind of goes against my intuition.....
Not MB72's, but DuraTracs on a black 4-door:As I get closer to buying time I'll have to keep comparing.
Its hard to compare without seeing them on a black 4dr.
MB72's look pretty good overall, will I need to get new bump stops?
Pic of the Daystar bumpstops. Basically, you mount the tire, measure distance btw tire and tailgate, and cut the Daystar's to fit. My spare is snugged down to the point that, even when I nail a pothole, I don't hear a sound from the spare.For the tailgate? Yes. Here's a pic of my tailgate now with the stock bumpstops:
As you can see, the stock bumpstops plainly no longer reach the tire. The MB72s have slightly less backspacing, so the tire will be even further away. That said, the set up is so lightweight that I'd guess there's not a lot of risk to the tire carrier while onroad. To go offroad though, I'd want it properly bumpstopped.
hmmm. How much more weight is the slightly wider?I've been following your discussion of 15" alloy wheels and 33" duratracs with great interest.
I actually asked this question based on the thread you linked me to before, based on a different wheels thoughFor the tailgate? Yes. Here's a pic of my tailgate now with the stock bumpstops:
The 33x12.5x15 Duratracs are also 49 lbs. It's the ProComp wheels that are lighter (16 lbs.) They also cost more than MB72s.hmmm. How much more weight is the slightly wider?
wont really help, the rotation of the tire is still the same..the width of the tire has nothing to do with the rolling resistanceThe 33x12.5x15 Duratracs are also 49 lbs. It's the ProComp wheels that are lighter (16 lbs.) They also cost more than MB72s.
10.5s should give better MPG than 12.5s due to less rolling resistance, also.
Actually, it does. A tire's specific contact patch directly correlates to rolling resistance. Try driving at speed with an underinflated tire. Mileage and the effort required to push such tires will fall and increase greatly, respectively.wont really help, the rotation of the tire is still the same..the width of the tire has nothing to do with the rolling resistance
:appl:Actually, it does. A tire's specific contact patch directly correlates to rolling resistance. Try driving at speed with an underinflated tire. Mileage and the effort required to push such tires will fall and increase greatly, respectively.
The Daystar tailgate bump stops are on backorder with every vendor. It's going to be a few weeks so when I installed my MB72/Dtac combo, I used rubber garage door bottom seal that you can get at Home Depot. I just rolled it up and stuffed it back there as tight as I could. Pic below:For the tailgate? Yes. Here's a pic of my tailgate now with the stock bumpstops:
