I installed a winch can it seems that the front is a bit more sagging. If I could get someone to measure from ground up to the bottom of the sidemarker. The dealer here doesn't have any Willys in stock to compare. Thanks in advance
Mine is exactly 33 5/8"
33 1/4" so only a 3/8" drop for the 100# mount and winch. Not bad
Retired Moderator
you have to take tires and tire pressure into consideration to compare measurements like that. JTphoto has it right that measurement will not change regardless of tire size/pressure etc. I can raise mine up by airing up to 35psi from the normal 26psi I run.
That makes sense. If it makes any difference mine are at 40 psi.
