stock wheels you will need 1.5 inch wheel spacers, going over speed bumps is the most flexing you will be able to do. but if you run wheels with 4.5 or more BS you can
Check out the latest issue of JP, or go their site. They are building a no lift 2013 Commando green JK on 35s.
Bigger tires will do you little good with room to work. Stuffing the wheel well with a big tire will not do much for increasing off-road capability. It will enable you to roll over slightly bigger pot holes than the stock tire.
