Bear with me... this might end up being a long story.
I recently bought a 2000 Wrangler Sport. My first Jeep.
At highway speeds, it started to vibrate a bit. Ok, time to get the tires balanced. So I take it to the local tire rip off artists to get a balance job done. They say they can't get a single lug nut off the front right tire, so they quit and gave me my money back without doing a thing. I drive home, and manage to get all the lugs off the front two tires. It wasn't easy, but it wasn't terribly difficult either.
But I couldn't get a single lug off the back tires. Broke several tools in the process. Tried everything, breaker bars, cheater bars, heating them with a torch, impact wrench (albiet a crappy one). Nada. Took them to a shop to have them taken off. It took a while, but they finally got them off by hammering on progressively smaller sockets with a dead blow hammer, then using a breaker bar and cheat pipe.
This was 10 days ago. We replaced all of the studs and the lugs, thinking one of the two was the reason they got stuck. They also put Lithium grease on all the studs before putting the tires/lugs back on. I checked each lug before leaving to make sure I could get them off.. and could. Tightened them back up with a socket wrench. No idea how tight (didn't use a torque wrench) but I didn't crank them down at all.
Fast forward a couple of days. I still needed to get the tires balanced, so I went out to check and make sure the lugs would come off. Guess what? All of them were tough to get off, but one just wouldn't budge. I ended up stripping it so badly (and breaking more tools in the process), I gave up and took it to a local shop. They're in the process of drilling out the (new) stud because they couldn't get it off either using any of the tricks they know either. And the rest of the lugs were on so tight, they had to use the heavy duty impact wrench to get them off, even though I barely tightened them the day before. Seriously... I was worried they were too lose, but just driving it down the street tightened them up so much they had to be impacted off?
I've heard anectodally that stuck lug nuts are common with Jeeps... but I find it hard to believe they'd get this stuck after only 10 days... and somehow tighten up just by driving.
Anyone have any ideas as to what's going on? And how to prevent it from happening again?
