1 - 20 of 23 Posts
So... I have a 1998 Wrangler TJ with 93,000 miles on it, 4 inch Rough Country lift with 33" BFG A/T tires. I have had a problem when going straight down the road at any speed my Jeep will just drift from left to right without moving the wheel, and when corrected the other way it gets worse. I have taken it to many experts and no one can help me out. This is what I have new on it since I have been trying to fix the problem:
New Steering box, steering stabilizer, drop down pitman arm, Rubicon Express adjustable trac bar, Rubicon Express adjustable upper control arms.
I have got an alignment each separate time after each one of those things were put on and nothing has helped. I've done the steering wheel wiggle test and everything is tight and all bushings are good. Tie rod ends are also good. What else can this possibly be?? Please Help! Thanks.
Have you tried to rotate your rear tires to the front and see what happens? Maybe your front tires have some issues you can't see causing the problem.
Make sure your toe and caster is set correctly
Seems like most run a stock pitman arm to keep the steering geometry correct and a drop pitman can cause goofy things (bump steer) to occur...but I am regergitating only what I have read.
Ive had that on there previously and was told a drop down would maybe help, but made no difference.
Knows a couple things...
First, what RE track bar & mounting bracket do you have installed? If you don't have the RE-1610 track bar which uses the RE-1611 dropped track bar mount (or a similar aftermarket dropped upper track bar mount), your Pitman are DEFINITELY should not be dropped. The Pitman arm should never be dropped unless the upper end of the track bar has a matching drop from an aftermarket dropped mounting bracket. Installing a dropped Pitman arm installed without that corresponding dropped aftermarket upper track bar mount will invariably cause bump steer. Older leaf spring Jeeps invariably required dropped Pitman arms after a suspension lift was installed. Not true with a '97 or newer coil spring Wrangler TJ that has a much better design steering geometry.
Next, exactly what brand & model steering damper do you have installed? A gas-charged steering damper can cause the steering to drift to the side, a hydraulic steering damper won't. Most steering dampers like from Rancho, RE, ProComp, Rough Country, Tera, etc. are hydraulic.
Also, are your axles square to each other and the frame? A bad installer might not have set the control arm lengths properly which can cause all kinds of handling problems. Your caster angles are fine, so is your toe-in (a tad high but ok) but I'd use a tape measure to make sure the axles are square to each other and to the frame.
I'm pretty sure its not bump steer, it does it on flat road. I have the RE1600 trac bar, Rancho steering damper. Should the alignment fix the axles square to each other?
Has anyone looked at your tie rods, ends and drag link. If those are worn then no amount of adjusting will help, also, lose the drop pitman.
Get rid of that pitman arm and go back to the stock one. The one thats on there is not even with your trackbar mount and is causing your problems.
The dropped Pitman arm won't necessarily cause it to drift but I guarantee it's causing your TJ to have bump steer... which is where the steering is forced left/right as the front-end moves up/down over bumps/dips on the road or trail... which could on some roads cause the steering to be forced left or right.
Regardless of what is causing it to drift, you really should replace that dropped Pitman arm with the OE factory Pitman arm. Whoever talked you into it didn't know the TJ well enough to know a dropped Pitman arm should not have been installed onto it... especially with your non-dropped RE-1600 track bar. The track bar and Pitman arm must match... both must be either dropped, or both must be undropped. One can't be dropped without the other being dropped without it causing bump steer.
35 psi is way excessive for 33x12.50 tires carrying a vehicle with the weight of a Wrangler. 26-28 at the most is appropriate. Make sure it's even on both sides.
1 - 20 of 23 Posts
