Probably.
I carried a stove there once.
Good Luck, L.M.
With the bench removed yes. With bench in place you are going to need some pancake woofers, IMO. I personally would go with size 10's in a ported box or something if you are keeping the bench.
A good set of tens with the right size amp will give you all the bump you want and let you keep your bench seat. Oh and don't cheap out on the RCA cables also consider bridging your amp to get a little more bass out of those 10s.
