I bought my 2002 TJ mainly for plowing. I have a lot of driveway and other snow removal options are too time consuming. Tonight I finally got a chance to get out there and try it out for the first time. There is a lot of backing up involved in snow plowing a driveway and I came to realize with the poor visibility of snowfall, the relatively pale backup lights just aren't cutting it. I need something brighter. I don't need auxiliary trail lights to make a mountain side glow. Just something 2-3+ times the output of the current reverse lights that hopefully can be wired on the same circuit so they go on-off with backing up and are road legal.
Any suggestions?
Quadratec's led tail lights have excellent backup lights... MUCH MUCH brighter than stock
Turns out there are a slew of options for replacing the bulbs with high lumen LED versions. I ordered a pair. Really cheap compared to replacing the entire tail light or mounting additional lighting.
You can do dropins but on the TJ the housing is really the problem.
Get a pair of 3" cubes and you can aim them however you want and get a good beam spread and actually see at night.
Wire in a manual switch and can use them as work lights too.
I added a bunch of LED bolts around the bottom of the bumper, can hardly see them durring the day but at night when I setup camp it lights up the whole area
02 TJ
I put some LED bulbs in my stock housings..while they did help over OEM, I still wanted more. So I added two cheap LED cubes onto my rear hitch and wired them into a separate switch so I can use them as work lights as well. Now I can see for days!
I simply put LED bulbs from Amazon in the stock housing as direct replacements for the stock bulbs. Big, but not monumental, improvement. Agree that the stock bulbs are close to useless.
Well, I can start with these and see how they work out. If they don't meet my needs, I'll have to take a different path.
I did 550 lumen LEDs from Diode Dynamics, a vendor up here. Very bright.
