The tabs that lock the frame to the door surrounds will not engage when I put the top up. Any suggestions?
I found it easier to lock the tabs in before locking down the header
I find it easier to lock ion the tabs if it's the first thing you do after raising the top. No tension on it at that point and you can move the top's frame around as required to get the pins to line up.
I'm gonna have to try that
Discussion Starter #6
I will have to try that as well. Thanks.
Discussion Starter #7
It works. I lock the tabs before I put the back of the top down, before the sunrider springs are in tension. Thanks for the tip.
