Wrangler Forum banner
I have a jk unlimited 2015 with the 3.6
I was wondering how easy is the tuning process and if i can actually use this product on my jeep.
Also the website has a disclaimer you must do a ECM swap???
How would i do that
Thanks guys
For the ECM swap you send them your ECM and they unlock it and send it back, ab a week your Jeep will be down.
Or they send u an unlocked ECM and a return label so u send back your ECM, no down time.
Or u buy an unlocked ECM from them and hold on to your stock ECM for whatever reason u want, most expensive method.
I have a '15 too and I'm waiting for more people to do it so I can see if they're having any issues with warranty stuff. Superchips told me that them unlocking my ECM wouldn't cause warranty issues but I rather wait a little while.
okay, but where do i get acess to it, like where is it on the jeep? like how do i get to it
It's under the hood, right behind the windshield washer fluid tank. I believe Superchips has instructions with pictures on how to disconnect and remove the ECM.
Unlocking your ecm WILL be obvious to Jeep if you bring it in for warranty work
(no matter what superchips says :) )
I did it with no problem. Go to YouTube and they will so you everything step by step. It has a selection for you to go back to factory settings if need be. That is if you are just changing tire size for your shift points.
Actually ANY changes to existing parameters will show up as 'changed' even it put back to stock...
those dang 'puters are pretty smart now-a-days :)
