:wavey:Now that I know that the red button is indeed a posi loc and not a primer button for the previous engine,as I was told by the PO, is there a way to tell how much of a suspension lift I really have? He said it has a 4" suspension and 2" body lift.Sorry about no pics waiting for a friend to show me how. 1989yj 2.5L TBI with 33x12.50r Pro - Comp Mud terrain tires.
Check the body lift at the mount bolts and push a tape measure in there. That will give you the body lift. You will have to take some pics and do some measuring on your rig to estimate the body lift.
measure in the center of the door stock is 18 with 28 inch tiers. Say it is 24 now u have 33 they usualy measure 32 witch is 4 over stock divide that in half witch is 2 24-2=22 22-18=4 then you have 4in of lift hope this helps
Thanks Again guys, I measured the body blocks at 2", and floor to bottom of the body at the drivers door at 241/2" if my math is correct I should have a 4" suspension lift where the extra 1/2" is comming from,to much tire pressure? What is a good pressure for on road driving?
