Anybody have any special tips for taking the roll bar bolts loose without having to drill the heads off?:banghead:
Most of the time you end up striping the bolts. So get someone to pull on the ratchet with a breaker bar. While you keep pressure on the ratchet, not letting it slip out.
I got the one on my project jeep off by grinding flat spots on each side and using a big spanner wrench. Worked quite well, but after that the bolt is toast. I'm planning on getting rid of the torx bolts anyhow, so I don't really care...
