I just converted my 94 wrangler from an automatic to the ax15. Everything is done but the jeep won't start now. I found that the crankshaft position sensor is different from an automatic to a manual. I bought a new sensor and now it will hit like it's trying to start but will not actually start. Any suggestions? I am out of ideas
I would check about the flywheel. Assuming you had a flex plate for the automatic, there should be a flywheel for the manual. The computer might be expecting the automatics pattern from the flex plate, and it is receiving the incorrect flywheel pattern.
I played with the distrubtor. After advancing the timing a little bit it started and ran. I have to put drive shafts in and a few other things but I will be taking it for a test run tomorrow to see how it does
