Weird issue. My sway bar end link bolts, that connect the end of the sway bar to the sway bar links, keep disappearing on me. Not sure why.
Every so often, I will notice some extra body roll, or some funky front end shuffle. Sure enough, one of the bolts is missing. This has happened three separate times.
The passenger side was very tight to align and get a bolt in, so I lengthened the sway bar link. I welded a 3/4" length of steel rod into the sway bar link. Now the bolt lines up when the Jeep is on flat ground at rest.
Still lost another bolt. I have lost one driver side, and two passenger side bolts. Anyone have this issue?
Yes and red Lockrite is your friend or get new locking nuts.
Make sure you use grade 8 bolts. I broke a few before I put stronger bolts/nuts on
make sure you have good leafs and pull your sway bar off and your track bar, better ride on road and off,,,,--i will never put mine back on...
