Awhile back I had asked a question about a front end rattle, one piece of advice was that the front sway bar links are weak, or get weak. After desiphering what is what (thanks to this forum) I found the front sway bar links. When I grab them and give a little push pull back and forth I do get some movement. Does that mean they are shot, or on their way out? Do I need to replace them? Do I use stock, or aftermarket? This rig will not be doing alot of off roading at this time. If I do need to replace them, is the install as easy as taking the bolts off and reinstalling, or is there more to it?
I also noticed tonight and wanted to ask about the part directly below the bottom mount of the sway bar link on the passenger side, it looks like a steel plate that has a upper and lower bolt, well the lower bolt looks like it gets rubbed a little by the steering mechanism directly in front of it, I would guess on right hand turns. Is this something to be concerned about?
Thanks again for all of your help, Scooby
