I just ordered a Skyjacker 2.5" lift and before I install it I need to know- are extended sway bar links required for a 2.5" lift? I have boomerang shackles on so it will add up to about 3" lift total when installed.
Yea my RE 2.5 kit came with them. I took the sway bar off altogether though.
Mine is a daily so I am not taking them off. Interested in disconnects soon, but I just need to know if the length of the linkage itself needs to be extended or if I can use the stock ones still
They gotta be extended so if you buy extended links then you might as well buy ones that disconnect. If you dont feel safe taking the sway bar off then dont but im just saying it helps alot with rough roads and doesnt affect handling. I have zero extra body roll, but then again i have stiffer lift springs. Again just my 2 cents, do what feels safe.
