Sway Bar
891 17
Ok guys, my front sway bar has fallen twice now, so that the bend is pushed down the opposite way. The picture is the first time and only the left side fell. The second time, both sides fell. Why is this happening?
Tire Auto part Automotive tire Wheel Automotive wheel system
1 - 18 of 18 Posts
You need longer front swaybar links to make the swaybar parallel to the ground. Currently you have stock links with the swaybar pointing down on any wheel downtravel the swaybar goes past the break angle (vertical) and attempts to rotate forward) not good
Discussion Starter · #11 ·
Yes, at the very minimum if cost is an issue you could try to find some stock rear links really cheap or free and put up there. They really aren't long enough either but would help. Some aftermarket adjustable or disconnects would really be the way to go though.
Thanks all! Price checked and they are not that expensive! Disconnects look good too...any brands you guys recommend?
I'd take it real easy offroad until you've had a chance to check everything over. At this point it seems like you're just short on a few parts. If you're not careful you could do some damage. Seems like you could use some disconnects anyway.
The sway bar links are easy to overlook when installing a lift but the previous owner may have done a hack job elsewhere too. With a 4" lift and stock links you are generating a lot of preload on the sway bar.
I have a 2" lift on my JKU and I had to buy new end links that are 8.5" long in order to get my sway bar level again. So, you need end links that are around 10.5" to 11" long for your 4" lift.
1 - 18 of 18 Posts
