Now that I have these JKS disco's on, I want to go use them. Actually, disconnect and not use them. My rubicon has the factory suspension. Is there anything I should be aware of as far as suspension travel, flex, etc? There doesn't seem to be anything to keep the axle from flexing too far now, and I don't want to mess something up. Thanks.
Your coils have bump stops on them (at least they should if all is factory). They should limit your flex from getting your tires into your fenders or over compressing your shocks.
Just had to shave an inch of my fenders because my 31's hit the factory fenders even with 2.5 inch lift when I'm doing some serious offroading with the sway bar disconnected. disconnect and you'll be fine with the axle but i wasn't with the fenders
