I've got an 2002 TJ with a 4 inch lift. I did a transfer case drop when I installed the lift. Everything works fine, but now I have some money for a SYE kit and new driveshaft. What do I need to know before purchasing such as other required mods?
I know the pinion angle on the rear needs to be adjusted. I have adjustable lca. Can I get the correct angle with with the lca or do I have to have adjustable uca also? Someone mentioned that I need adjustable uppers. Wasn't sure if that was correct or if there was anything else that I wasn't aware of.
