Transfer case is slinging oil from yoke to bottom of jeep body . Seal on shaft is not leaking I was told that they can loose oil thru splines on sling it from there. What is the best fix for this? Same person said Teflon tape on splines or paste on spines ?? Sounds ok but is there a better way
zombie & ninja slayer
Make sure the gasket behind the yoke is good, and the nut is tight
Yup yoke was loose thanks , my SYE kit showed a gasket in parts list but did not include with kit will get one ordered tomorrow thanks
