1 - 11 of 11 Posts
I'm in the process of building my jk with a new steering setup from top to bottom , what would you all reccomend. Either synergy or teraflex ? Done extensive research and am stuck between these two brands for the tie rod drag link and track bar .. any suggestions ?
If you are stuck don't look at the whole bar just focus on the joints and pick the joints you prefer.
It's a 4 in lift , the guy that had it before me didn't bother to put the time or money into components that go with the lift, ie drive shaft , steering ect, but if I'm going to replace I'm going to do it right .... Just empty every pocket and upgrade it all :D.
Average jk ,that is the exact thing I have in my cart haha, don't forget the wheel spacers if you need them that is.
Discussion Starter · #11 ·
Check out northridge4x4 with the discount code wranglerforum. Cheapest I've found. I'm just waiting to see if their 5% off discount changes to 10% in June.
So glad you said that , from all the other sites it's much cheaper through them
1 - 11 of 11 Posts
