Does anybody know why the synergy sway bar disconnect mounts wouldn't work with RK quick disconnects? Synergy's website says only compatible with Synergy quick disconnects, but from looking at the pics I can't see it wouldn't work with others. Unless the studs are a special size or something.
All the manufacturer's say that. It is because the pins are bigger than stock and they can't confirm that they will work with anybody else's stuff. Also they want you to buy there stuff.
If you can find the dimensions of the pins and compare them to other links that would answer your question.
