Hoping you folks can sense check these selections for me for our 2011 6-speed Sport, with a rear LSD. I'm looking at the synthetics to improve gear efficiency.
Diffs:
T-case:
Transmission:
Diffs:
Front:
Spec:
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
Synthetic:
Mobil 1 Synthetic Gear Lube LS 75W-90
Mobil 1 Synthetic Gear Lubricant LS 75W-90 is SUITABLE for use in modern high performance automobiles like SUV's, Vans and Light duty trucks requiring API GL-5 level performance
Rear:
Spec:
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent. For trailer towing, use MOPAR Synthetic Gear & Axle Lubricant (SAE 75W-140) or equivalent. Models equipped with Trac-LokTM require an additive.
Synthetic:
Mobil 1 Synthetic Gear Lube LS 75W-140
Mobil 1 Synthetic Gear Lubricant LS 75W-140 is recommended for use in modern high performance vehicles like sport utility vehicles, vans and light duty trucks requiring API GL-5 performance that require excellent durability
Mobil 1 Synthetic Gear Lube 75W-140 LS contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid.
Question: Add the Mopar additive or not????
I'm thinking "Yes" if for nothing else than to not have any warranty questions if needed in the future.
T-case:
Spec:
MOPAR ATF+4 Automatic Transmission Fluid or equivalent licensed ATF+4 product.
Synthetic:
Valvoline ATF +4™ Full Synthetic (Designed to meet the specific requirements of Chrysler, Dodge & Jeep vehicles)
Transmission:
Spec:
MOPAR Manual Transmission Lubricant or equivalent (meeting the re- quirements of Chrysler Material Standard MS-9224).
Synthetic:
Amsoil Synthetic Manual Synchromesh Transmission Fluid (MTF)
Specifications include:
• Chrysler MS-9224
• Chrysler MS-9224
