1 - 1 of 1 Posts
After upgrading to LED's I cannot get rid of the hyperflash on my passenger side (i had hyperflash on the halogens, one of my excuses to upgrade). I have tried everything the internet has been able to offer from resistors, to running new ground wires. When I first start the engine and check the turn signal, it works fine. It is not until I drive 5+ miles and use the turn signal that the hyperflash begins. If I turn off the engine and leave the ignition in the on position or ACC the turn signal works fine. I have only noticed 2 things that seem out of whack.
1. Anytime I open a door or the rear gate the rear passenger light flashes.
2. Even after removing M18 (15a) from the fuse box the lights still work.
I am at my wits end. Any suggestions???
1 - 1 of 1 Posts
