1 - 20 of 34 Posts
I think that is what the part is called. It is the bar that holds the tailgate open.
Previously the tailgate would open with a slight audible catch.
I have removed and remounted the spare tire and now the check rod has a really load snap when it reaches the end of its travel to hold open position.
Is this just coincidence or could something have happened to move the rod out of position?
Should I be lubricating this rod?
I searched for a parts diagram to see how this works, but was unsuccessful.
Any assistance would be appreciated.
Just concerned that I broke something.
'15 2dr
stock wheel/carrier/bumper
TIA
ba
Mine snaps pretty loud when it gets fully open. If you broke it, it would just be flopping around and doing nothing. They are apparently easy to break.
Tighten the mounting bolts. That's what fixed the noise & 'catch' on mine.
AWESOME !!
barely noticeable, but the bracket WAS loose and snapping against the panel.
THANK YOU !!
ba
There is a TSB out regarding the tailgate retaining strap for 2012 thru 2014.
Attached below is the TSB for those visiting this thread who may be interested, or not as fortunate resolving this issue by tightening things up.
Thanks for that. I wonder if there is a stronger replacement or a modification to make it better somehow? The TSB doesn't show a better strap that I can see. Maybe a cloth strap, like on the doors, that could tighten up just before the retainer gets to it's stop?
Interesting that the TSB refers to the application of a sealant between hinge and body to prevent corrosion. wonder if this sealant was used on all hinges from factory?
x2 jac04
My 2011 made the same noise. Turns out the bracket which attaches to the gate was loose - two torx bolts - tightened them and all is well.
I had loose bolts on my 2013 JKU too. I took the bolts out and put on some Loctite then tightened them up.
yes! I used to have to tighten every few months. Last time I added some blue locktite and it's been solid as a rock ever since.
That was the problem with mine too!!! Sheesh. Never noticed the loose bolts. Thanks!
As a side note, mine made the snapping sound too - when the rod snapped the plastic catch inside the body side mount. You can look inside mine and see the white plastic housing separate when it hits the end of the arm, the only reason my arm doesn't pop out anymore at this point is because the screw I put in the arm in the back catches and holds it in.
This Fix Works! New Hinge is Much Stronger.
I had this done to my 2013 JKU last year. It works perfectly. The new hinge is significantly better than the old hinge and will not fail. This is the correct fix for this problem. Don't mess around, get it fixed right. Remember it is the hinge that stops the door, not the strap!
I had to convince my dealer to fix the problem. Now there is a TSB and it is easy to get them to fix it!
Discussion Starter · #18 ·
Does anyone know the torque spec for the 2 bolts on the tailgate side of the strap?
Thank you
ba
I'd really like to see a picture of the new hinge. Any chance?????? And I'm assuming it's not not under warrantee, so what is the cost?????
1 - 20 of 34 Posts
