1 - 20 of 24 Posts
I have a 2 Sport. Recently I experienced 3 "white Knuckle" driving experiences that have made me think my Wrangler just isnt safe enough for me.
Twice I have hydroplaned at low speed, the rear end just loses it. Last night I was driving at highway speed, 65, I slowed to 60 because a bus was in the middle lane, I was in the right lane, and I didnt want to pass the bus at 65. The road had some kind of dip, or rough patch, the back end kicked out and I jumped into the middle lane where another car was, lucky for me he was able to react. I know my Jeep is not a precision driving machine, but I just dont feel safe.
Before I jump ship and trade it in, what can I upgrade? Shocks etc?
I know the short wheelbase does not help. Maybe a 4 door in my future?
Thanks!
Ami
Retired Mod
A 4 door (longer wheelbase) and different tires will feel much safer. (It is still a RWD, solid axle vehicle....but will be more stable)
From the looks of your avy, you are on the 29" Goodyear Wrangler ST's....those are not exactly the best tires out there.
I'd start with new tires....(and wheels...why not...)
Retired Mod
The Goodyear SR-A's are better than the ST's, but the Silent Armor's are really what you would want for rain traction.
How many miles on the tires?
How much air in the tires? Too much air, or not enough air?
I just learned in my Duratracs @ 28 Psi will let it lift a tire in large puddles on the interstate, where 33 PSi stayed planted through the same kinda puddles on the interstate.
Good luck
What kind of tires?
+1 Tires. I had a car a few years back that came with Goodyear Eagle RSA tires on it. Starting around 5k miles, it was terrifying to drive in the rain. The change came on really suddenly, too. I put a new set of Bridgestone tires on it, and it was rock solid again. Never had a hairy moment in the rain again, as long as I owned the car (through two sets of Bridgestones, run all the way to the wear indicators).
The old tires still had plenty of tread on them, so you can't go by that, necessarily.
Good luck
I have about 7k on the tires. PSI is at 32.
Have been thinking about replacing with Duratracs.
For rain, tires could be the problem, as well as PSI as stated above, not so much the axles, shocks or coils. Surely stability control can help, and a limited slip differential will help even more and probably is the option that will provide more change and control on wet roads.
However, the ass jumping seems to be a mix of parts, overly inflated tires, stiff shocks and coils and possibly, binds in the trackbar or control arm bushings. That also happens to me in deformed roads with tall bumps, as soon as I pass above it, the rear of the wrangler jumps and lands in a different place, obviously not on another lane, but if caught off guard, it could be enough to lose control.
If the rear jumps are happening on a stock JK I would look onto changing the shocks, something like the adjustables ranchos and dial them down to the softest level and see how it goes from there. Not gas charged ones as they are stiffer.
Discussion Starter · #12 ·
However, the ass jumping seems to be a mix of parts, overly inflated tires, stiff shocks and coils and possibly, binds in the trackbar or control arm bushings. That also happens to me in deformed roads with tall bumps, as soon as I pass above it, the rear of the wrangler jumps and lands in a different place, obviously not on another lane, but if caught off guard, it could be enough to lose control.[/QUOTE]
The experience last night was on dry pavement.
But yes, if caught off guard, its enough to lose control. I about Sh!t myself!
Tj's would spin like tops! I figured the jk's longer body would have helped that. I have a jku and feel pretty safe, it also has stability control.
Not a fix, but have you ever run with passengers or extra weight in the back and noticed the same thing?
(Edit, guys who have driven leaf spring Jeeps and trucks with stiff rear leafs will follow me here, sometimes the suspension is just too stiff and weight seems to balance it out a bit)
Discussion Starter · #15 ·
Dont often run with passengers.
Would the consensus be new tires?
Rubi suspension? Shocks, dprings?
Would be cheaper than a whole new Jeep!
How many miles on the rig? is it all stock?
I had an ol truck that had stock shocks on it, at 95K miles, would spin around and brakes would lock up with any rain. Changed the shocks- fixed everything.
I put my vote on new tires and some weight in the back. Get 4 bags of water softener salt ($20 max cost) and put it in the back by the tailgate or you could get an after market rear (real) bumper instead of the plastic hollow sorry excuse for a bumper that is there. That will weigh it down a bit. I plan to get Duratracs due to my driving style in rain (only heard good things about their traction wet or dry). Good luck.
You shouldn't have to go through all this bs just to be able to drive a relatively new stock Jeep. Either something is wrong with yours, or you just need to get used to driving a short wheelbase vehicle like the Jeep. They don't drive like cars and they certainly don't like hitting puddles on the side of the road! I think part of the issue is this is just how Jeeps drive. It takes getting used to.
1 - 20 of 24 Posts
