Well, I had some down time this afternoon and had a chance to do more research. Definitely the opda. The replacement procedure looks pretty straightforward, much the same as removing/installing a distributor. I understand indexing the pointer/housing/block, but is there anything else I should look for? Is a stock replacement the only one I can get ? Will it do the same thing in the future or has the manufacturer made improvements to it ? Once again, thanks !
