found em...they're ~$900
If you go with an Atlas you then also have the added cost of modifying your drive shafts to match it.04moneypit said:Check with four wheel drive hardware www.4wd.com
I think they run about $900 for NP231 conversion. But for the money and if you have to have it installed, you are better off just going to the atlas case for the strength of an all gear transfer case. Just a thought.
