Question- can I add another inch in both the front and rear? So the front would have a 2" spacer plus and .5" spacer and the rear would have a 1" plus a .5" spacer.
I guess the question is can spacers be added on top of each other given I already have the leveling kit? Seems to be the cheaper option at this point.
Discussion Starter #2
Actually look to add 1" to the front so I would have 2 plus 1 in the front and 1 plus 1 in the rear.
You probably could but are close to needing extended sway bar links, possibly extended shock brackets and extended brake lines and I think the steering would be flighty.
Better off with just adding another half inch in the front and back versus 1 inch?
