I want to say no. I remember TF saying they did not make a fixed arm at one time.Arent these the same control arms that come with the Mopar lifts?
Just ordered some 35" MTR's, (60 day backorder), I think I'll pick these up from Teraflex while I'm waiting. Thanks for the infonow.. I got the front lowers last week.
No problem.Thanks for sharing Ken!
I think this is only sold as a upgrade kit. I like the fact you can buy them separately too.I'm very interested to see what the full kit is going for. Will they list without shocks like they do their other kits? That's one of the things I really like about TF, they let us buy what we want and not force a specific set of components on us.
I guess you can add it to any of the 2.5 - 3" kits, but I think it would be a great gap filler between a regular 3" kit and a 3" full flex arm kit which is nearly 3 times the price.I think this is only sold as a upgrade kit. I like the fact you can buy them separately too.
The regular flex arms are adjustable. you can fine tune them at any lift height.So what is the difference in these arms and the other arms they sell? One fixed and one is adjustable, right?
These lengths match the arms that come with the mapar 3" lift. In fact they are within 1/16" of what I measured. Although the Mopar kit does not come with front uppers. The Mopar arms appear to be much stronger and are heavier than the stock arms. I measured 1-5/8" O.D. on all arms. I'm curious to know of the TF arms are the same.... Did you happen to measure the diameter of the tubing? Also, do the TF arms come with Tenneco bushings?What a cool setup for lifts 2-2.5" Arms are preset to give a little caster bump. move the axle back 3/16 and pinion + 1/8 for the driveline.
Here's the arm lengths I researched a month ago
Front upper 18 3/4 = stock
Front lower 22 13/16 = + 3/16
Rear upper 17 11/16 = + 1/4
Rear lower 19 15/16 = + 3/16
Stock Clevite on the bushings. Assuming the arms are stronger. The front uppers are stock in length. They're would be no point in replacing them if the same strength/diameter.These lengths match the arms that come with the mapar 3" lift. In fact they are within 1/16" of what I measured. Although the Mopar kit does not come with front uppers. The Mopar arms appear to be much stronger and are heavier than the stock arms. I measured 1-5/8" O.D. on all arms. I'm curious to know of the TF arms are the same.... Did you happen to measure the diameter of the tubing? Also, do the TF arms come with Tenneco bushings? Good work ken!
