1 - 17 of 17 Posts
I purchased and installed this kit and had a question regarding this or any other lift kit. It seems my right side of my jeep is about an inch or so lower than the left. Is this a defect in the springs or is it one of those things that isn't perfect? It seems like it should be level but I noticed it and measured and it is for sure lower in the right side. Any advice or comments would be great. Thanks
You should not be lower on one side then the other. The only thing I can think of is to check and make sure your spring(s) are seated properly.
I AM THERE4 I JEEP
Gas tank. Did you just fill up your jeep?
Or...
Did you re-install both factory isolators atop the new front coils?
I did just fill up but it is not level without fuel. I never measured right after the install so I am not sure on the actual lift. I just know one side is over an inch higher.not sure in the seating or retainer either. May have to double check this. Thanks for all the replys
Mine is the same is no lean whether tank is empty or full.
u mean if it was full the driver should be higher. i just dont see how it would make much of a dif
I agree. there should be no lean whether full or empty. When I measure from the ground to the lower fenders when parked on level ground my driver side and passenger side are the same.
I believe the balance is in conjunction with the driver...meaning a driver in the seat and a full gas tank. If it's that bad then maybe double check your lift components and make sure everything is sitting properly.
1 - 17 of 17 Posts
