This should be obvious but I'm going to be test driving TJ's next week prob 2003-2006 year ranges and was wondering if there are any issues I should be on the look out for... I am aware that Death Wobble is a concern and I plan on running it through the paces by trying different speeds and hitting the wake up strip on the highway going about 55. I'm thinking that would let me know if it's an existing issue. Am I correct in thinking this? And are there any other issues I should be on the look out for? Thanks in advance...-Mike
Knows a couple things...
Personally I'd stay with 2003 or 2004. 2005/2006 have a known problem with the oil pump shaft that has not proven to be an easy fix.
Try to find one as close as stock as possible, no outrageous or crappy lift kits installed etc and definately look for one with a Dana 44. Good luck !
