Hey guys, I got the TF 2.5 Coil lift from TeraFlex (1351002). I just noticed today the rear axle is about an inch moved over the drivers side. Too dark to get accurate measurements right now, I understand this is a "sideaffect" of lifting. The trackbar was installed on the top hole of the JK 2.5" Rear Trackbar Axle Bracket Kit(1954776). Would mounting it in the lower hole center it more (this is what I thinking relying on my old geometry) . And if so, how much would it bring it over? I just don't want to transfer the inch to the passenger side. And I know that you will say an adjustable rear track bar probably be the best thing. Thanks in advance
The write up for it says "The JK rear trackbar bracket is designed for 2.5” lifts, and offers multiple mounting locations for correct neutral lateral alignment of the rear axle." but the instructions https://teraflex.com/file/attachments/55cbde9d8bcbf000861ff7cb.pdf does not say the lower hole will 1) brings axel over more to the passenger side 2) how much
