As some of you may or may not know ive been on here asking all kinds of nooby questions about installing my lift,my sye,what control arms to get,if i need adjustable track bars
you get my point. i started this thread(with pictures of course) to thank all of you that gave great advice in helping me with my choices! I received a 4" teraflex suspension kit for christmas which came with springs,t-case drop,sway bar links,bump stops,track bar bracket & the dreaded drop pitman arm. So after asking around here i wound up using springs,sway bar links & bump stops and then adding to the kit(with wf input)advance adapters sye/tom woods driveshaft,front & rear adjustable upper control arms,front & rear adjustable trackbars,rancho 9000 adj. shocks,rancho 5000 steering stabilizer,currie shock relocaters & re front brake lines. This is the cool part i put this thing together with all the input from you guys and i havent had 1 issue with driveline angle,vibration,alignment,caster,toe!!! it handles great on the road at any speed with no sign of DW all the up to 75mph.What else can i say but THANK YOU for taking the time to answer the same old questions it is and was greatly appreciated!
