Vendor
The Scientists of Lighting have figured out how to drive our LEDs harder, safer and more efficiently. Almost half of our LED products are now BRIGHTER, BOLDER, BETTER.
XL Sport and Squadron Sport LED auxiliary lighting
up to 30% BRIGHTER
- Increase lumens from 2,260 lumens ⇒ 3,150 lumens
- Increase watts from 20 watts ⇒ 26 watts
- Increase amps from 1.4 amps ⇒ 2.0 amps
S8-series LED light bars (per 10” section)
up to 40% BRIGHTER
- Increase lumens from 4,520 lumens ⇒ 6,350 lumens
- Increase watts from 45 watts ⇒ 60 watts
- Increase amps from 3.2 amps ⇒ 4.0 amps
OnX6+ LED light bars (per 10” section) up to
69% BRIGHTER + includes new Battery Management Technology
- Increase lumens from 7,350 lumens ⇒ 12,450 lumens
- Increase watts from 58.5 watts ⇒ 108 watts
- Increase amps from 4.2 amps ⇒ 8.4 amps
HI-POWER IS OUT, PLUS IS IN!
We are dropping the Hi-Power line, but offering the brighter and more affordable OnX6+ light bars with a starting MSRP of $429.95. Not only is the OnX6+ line brighter, but we are integrating brand new technology at the same time. Baja Designs’ new Battery Management Technology (BMT) is a game-changing feature designed to keep your lights running at your vehicles maximum potential. This additional protection allows us to drive our LEDs and circuit boards harder, without risk of failure or damage. When your vehicle’s voltage drops below 13.5v, your light will begin to gradually dim until voltage is stabilized. BMT eliminates flickering under low voltage and protects your vehicles wiring and electrical system from dangerous current spikes.
VISIT WWW.BAJADESIGNS.COM FOR MORE INFO!
BAJA DESIGNS
WWW.BAJADESIGNS.COM
Vendor
Discussion Starter #2
Baja Designs OnX6+ LED Light Bar
At 12,460 lumens, the brightest just got up to 69% brighter than our previous generation OnX6 series, at the same cost. The OnX6+ LED light bar integrates Baja Designs’ trademarked High Speed Spot reflectors, the same ones used by our team enlightened racers, to give you the guaranteed furthest projecting LED light bar.
With the all new integrated Battery Management Technology (BMT), our engineers have put substantial efforts to ensure our OnX6+ are running at 100%. Our new BMT feature maintains a constant current under voltage drop. So when voltage drops below 13.5 volts, the light bar will begin to gradually dim, protecting your vehicle’s wiring and electrical components from dangerous current spikes and eliminating flickering under low voltage.
AVAILABLE HERE
Baja Designs
www.bajadesigns.com
