In preparation for our upcoming trip from South Africa to Morocco, we are building our '07 JKU . Our goals are increased durability and improved reliability. To that end, we have sent the Jeep to Bruiser Conversions for a Cummins 4BT among other changes. Full Build Sheet is below.
Though we do have a couple of gear sponsors, the goal of this post is not advertising or marketing for anyone. Brand names are included for the items on the build sheet so people know the details of our build.
I spent a lot of time researching prior to choosing a 4BT Jeep for the trip. With gasoline less available than diesel, and the diesel they do have is not the low sulfur, clean diesel we have here in the states, the 4BT is a great choice as it can handle a wider variety of fuel "qualities" than newer engines. On top of that, it is the only platform I have found that has a proven track record of working in the JK. I have heard of Mercedes and VW diesels installed into Wranglers, but not with nearly the frequency and success of the 4BT. I am always excited to discuss the Jeep, the parts and services we chose, and learn more about how to make this Jeep a reliable and durable vehicle to get us through our journey.
Bruiser should start on their part just after the first of the year, unless we get lucky and a spot opens up in the shop earlier than that. Given the timeline from Bruiser, we should get the Jeep in mid February and drive it home to Oregon as a shakedown trip. We will have a few items to add after we get home. Once here and complete, we will ship the Jeep to South Africa and start exploring. Check out the trip, and our prep thus far, at
Started With:
Pronghorn Overland Gear MFES-JK C1
Warn 9.5 XP-S Winch
Gobi Rack Roof Rack
Road Shower Solar Hot Water System
Bundutec Bunduawn 3-Side Awning
HiLift Jack
Shovel
JW Speaker 8700 Evolution 2 LED Headlights
JW Speaker 6145 LED Fog Lights
Mac's Custom Tie Downs Black Box Cargo Drawer
Bartact Seat Covers w/Mil-Spec PALS Webbing
Drake Off-Road Turnbuckle Hood Tie-Downs
Bolt Hood Lock
Daystar Upper Dash Panel Organizer Tray
Jeep Rubber Floor Mats
Blue Ridge Overland Gear Expedition Organizers
Jeep JKU Attic
JK Door Handle Pouches
JK Grab Handle Pouch
JK Headrest Panel and IFAK Bag
Bruiser will add:
Cummins 4BT conversion
Moderate power increase, ~150 HP, ~400 ft-lbs torque
NV4500 Transmission
Transmission case breather extension to raise level of transmission case breather, with large gauge hose
A-Pilar Gauge Group
EGT Gauge
Engine Oil Pressure Gauge
Lift Pump Low Pressure warning light and alarm
Rubicon Transfer Case (4:1 Low Range)
Transfer case breather extension to raise level of transfer case breather, with large gauge hose
Ultimate Dana 60 Rear Axle
4.88 Gearing
Eaton E-Locker
Axle case breather extensions to raise level of axle case breathers, with large gauge hose
New Drive Shaft to fit Larger Axle, Retain Stock U-Joint Sizing
New Parking Break Cable to fit Larger Axle
Ultimate Dana 60 Front Axle
4.88 Gearing
Eaton E-Locker
Install axle case breather extensions to raise level of axle case breathers, with large gauge hose
Larger master cylinder for brakes, due to larger rotors on the new axles
Gen Right JK 20 Gallon Dual Gas Tank
Rock Hard Sport Cage
Snorkel, with cyclone dust separator
Metal Cloak Overland "Elite" Suspension, 2.5", RockSport Edition
Currie Anti Rock sway bar
ARB CKMTA12 Dual air compressor
Braided Stainless air lines run to both front and rear bumper
Genesis Off Road Dual Battery Tray
G-Button included
Optima Red Top for cranking battery
Optima Yellow Top for accessory battery
Heavy gauge lines run to front and rear bumper with Anderson plug, for winch and trailer power
Convert trailer lights plug to South African standard trailer plug to rear bumper.
S-Pod 8 switch solid state power control module.
Front and rear lockers wired to S-Pod
Compressor wired to S-Pod
Wire in electric fan shut off switch to S-Pod
Hutchinson Rock Monster Wheels, to fit axles above (silver color for Chevy HD Trucks per Rock Monster web site)
BF Goodrich T/A KO2 tires, 35X12.50R17
Include spare (total: 5 wheels & tires)
HTML:
www.thepioneeringspirit.com
Started With:
Warn 9.5 XP-S Winch
Gobi Rack Roof Rack
HiLift Jack
Shovel
Bolt Hood Lock
Jeep JKU Attic
Bruiser will add:
NV4500 Transmission
A-Pilar Gauge Group
EGT Gauge
4.88 Gearing
Eaton E-Locker
4.88 Gearing
Eaton E-Locker
G-Button included
