I bought a new 2017 Wrangler two door about two years and half ago . I did the free service for four oil changes then did It myself last week . I found the expansion Tank was totally empty not good . I found no leaks the Jeep is parked in the same spot all the time at home no leak under it . The oil in the drain pan is fine no water i change at 4,000 miles . The Jeep just turned over 20,000 miles with zero problems . I never did look in that tank before last week the Jeep ran cool never got hot and the heater works fine .
The dam thing may have been low setting on the dealers lot new .
for the record they come straight from the factor at the minimum line. I have had 4 new wranglers and every one was that way.
Retired Moderator
Its a good idea to check both your coolant and engine oil level's at gas fill ups.
Wranglers have a coolant vented system, so some of the coolant will evaporate.
Reactions: jadmt
I have read this before. Any idea how much might evaporate per say 1000 miles?
I do periodically smell coolant, albeit not a very strong odor, like the other day when out driving in the x-mas tree fields looking for a tree.
jadmt Thank You I would think it would be to the full line when new guess not .
Also it being at the dealer four times for an oil change and not filled to full line .
I guess you get what you pay for .
you actually don't want it at the max line otherwise it slops out when you are offroad. I made that mistake once and only once.
I always say if the minimum wasn't enough then it wouldn't be the minimum.
