Agreed with above. The top does not come all the way down like the factory top, but it is super easy to just put it into sunrider position. Even when I had the factory soft top, I put the top in sunrider position much more often then all the way back.
The windows unzip easily and can be thrown in the back. You can remove all windows and the back, and leave the top on as a bikini type top too.
If you want to take the top off and stow it in a garage, I personally think it is lighter and easier to do than doing the same than the factory top. I did that once when I needed to haul something awkwardly shaped that was higher than the top would allow.
If you want a top that can roll all the way back, get an old generation trektop. It velcros in place and is not a flip back type top. You can roll it back to sunrider or roll it back all the way or take it off all together without the frame.
