1 - 17 of 17 Posts
I’ve never lifted anything, I’ve thought though my jeep would look nice with a mild lift. I’m thinking about going with the daystar 3/4 inch lift. I have a few concerns though, would something that mild hurt any of the suspension components? I’ve upgraded all my shocks to fox shocks a few years ago. Does it make sense to lift something that is nearly 10 years old?
I don't see any issues with it. You'll prob restore some sag in your factory coils with the spacers as well.
Reactions: Wandell
‘16 JKUR soft top manual. 2” Frankenlift.
The only issue is that you may get done and decide it’s too mild. It’s not a small undertaking to put a spacer lift in.
I’m not sure 3/4” would be noticeable and do much for you. Tend to agree that I wouldn’t bother unless it was more.
Installing 4 little spacers on factory springs couldn't be any easier unless you live in front of the beach and have never touched the bolts in the Jeep in years :)
PB Blaster for the win!
It’s not difficult, but it is time consuming.
probably good experience though. Then in a year when you decide to put a 1.75” spacer up front, you will have the expertise
hey man. Just getting back into having a Wrangler again. I never lifted my old TJ just shoved 31” tires on her with wheel spacers.
If I were in your boat…
I honestly wouldn’t waste the time, money, energy. Just go to a 2” - 2.5”.
You actually look like you lifted it a little.
That’s my two cents.
2010 JK
If you're looking to run 33s, go for a 1.5" front 1" rear spacer lift. You will need a kit that includes longer sway bar links, and 1" more bump stop. 0.75" is barely noticeable.
I would do this above if you just want a spacer system. I've seen cheap spacers deteriorate.
Dear lord, if you ought to spend $300 on "spacers" might as well lift it with a cheapy lift. Little more gets you at least spring and shocks. Lol
Dang it we're good at managing other people dove :) Btw Daystar poly spacers are Made in USA.
2010 JK
That Rancho kit is not a complete lift at all, though. There are a lot of required parts missing.
Lol, Don't we have a big thread about that same Rancho kit ? it's cheap and according to those in the thread it doesn't need anything else. I won't argue about what it has or doesn't i would not run it myself, but just saying if you ought to compare an "AEV" $300 spacer kit, might as well go with something that at least can carry a little weight and replace the factory shocks with a new fresh set.
1 - 17 of 17 Posts
