Wow....here it is the 19th and not one single response...... hopefully by now you have figured out the cure....if not, before you start throwing more parts at it, I would suggest you examine/clean all of your electrical connections starting with both battery posts [assuming the battery is in tip top shape] and including all of your ground connections. Please let us know what fixes your problems!
