1 - 20 of 35 Posts
Hey everyone,
I just got my first 1993 jeep wrangler, its a 2.5 4 cyl.
its in overall good condition, but im hearing a ticking noise coming from the engine bay.
Do any of you have any idea what that might be?
I was told to use a stethescope ( sp? ) to pinpoint the location of the noise. I put the stethescope on the valve cover, and i heard alot of noises. Im not too sure if it is the exact noise, because the valvetrain has alot of parts moving around.
Thank you in advance.
David
X3 on the lifters, how many miles does the rig have?
x4 on the lifters. When i first got my 89 yj it had some ticking noise. We messed around with it for a while and finally found out it was the lifters. They dont cost all that much but its alot of work for those little things.
hey man i have a 94 wrangler. and on mine i had a horrible ticking sound and i found out that is was coming from two places the donut and at the manifold where it meets the head. from what i have been told is that the very last manifold bolt is very weak. and alot of them will break off. i have ordered a new header and cat back exhuast kit.and i am getting the bolt tapped out. i don't know if that helps but that is what it was on mine.
daddyjeep said:
You may also want to take a look at your exhaust manifold. A leak where the manifold meets the head will also make a ticking sound.
BUMP!! the exaust manifolds are famous for cracking, the only thing good about yours is if its a new head the nuts wont be rusted on the studs so it will be an easy swap to put in a header!
Discussion Starter · #14 ·
i think it does actually go away slightly when the engine warms up.
it takes a while to go away, but i think it does. And, if it doesnt go away, its very..very very slight.
how do i check to see if it coming from the manifold?
and would putting headers on this car do anything? i have a 79 trans am as my fast muscle car, i do not need this jeep to be fast by any means haha, but any nice jump in power is appreciated.
Dave
by putting a header on your jeep it will allow it to move exaust gasses out of the cylinder head faster which will result in more horsepower, and tourqe the 4 banger needs all it can can get expecially when running larger tires.
Discussion Starter · #17 ·
if it is an exhaust leak. Should it go away really fast when it warms up, or will it just quiet.
When i first start it, its pretty loud, you can tell its there. But after a while, its like reallllly quiet. And im not sure, but i think its gone. But, it still might be there.
David
the donut is where the head pipe connects to the rest of the exhaust. or thats what i have always called it. it is a flat piece of metal with three nuts and bolts holding the two pieces together. sometimes they will rust and break or there might be a crack there.
Discussion Starter · #20 ·
well guys.
The noise doesnt go away. at all.
Not even to the slightest imagination.
I started the jeep up, it was there, and fairly loud.
Then, i drove it around, got her nice and hot. And the noise got a little quieter, but was still there never the less.
So, you guys think its the lifters?
David
1 - 20 of 35 Posts
