1 - 1 of 1 Posts
So my '98 TJ had a high steer on when I bought it. I just converted back to a y-link with the currie currectlync system, however due to the high steer the taper on my tie rod ends is too narrow to fit correctly with the y-link ends. I need taper inserts but want to be 100% sure that the stock tie rod end taper for my 1998 TJ is 0.75"? I called teraflex, who make different sized inserts, to double check with an employee the correct stock taper width.
TIA
1 - 1 of 1 Posts
