My apologies if this has been asked before. Can this tie rod end be taken out and replaced or do those grooves indicate that it is pressed in?
Pipe Exhaust system
Its not meant to be serviceable. You can get it out with heat and what not. If you have 17 inch wheels I'd look into ruff stuff kit
Yea I figured, I do plan to upgrade it in the future but hadn't planned on doing so right now. The ruff stuff kit is a damn good deal though. Thanks for the input!
When you buy the passenger side it should include the end and the bar. You can get the entire assy knuckle to knuckle from Extreme Terrain for under $130.
Retired Moderator
I've been having the same issues and questions because mine actually has some kind of clamp on that end as well. My steering has been sloppy so I'm wanting to change this out. I've already replaced the upper/inner tie rod on passenger side and the one on the pitman arm.
I once bought Moog tie rod ends all around before knowing that it wasn't serviceable. In a fit of rage, anger and spite I damaged the Moog end and ended up replacing the entire assembly with Synergy. I couldn't return the Moog ends after that. :pullinghair:
hindsight, I'm happy with the synergy for sure and its ALL serviceable.
