1 - 20 of 24 Posts
So I just got back from 4 wheel parts... Turns out I need to replace my tie rods and passenger upper and lower ball joints. I'm gonna do the synergy ball joints, cause I still have a warranty. I'm not so sure as to what brands I should go with for the tie rods. Also, as far as I know, there is 1 tie rod, 1 trac bar, and 1 drag link... Is the drag link the second tie rod?
I AM THERE4 I JEEP
There is only one tie rod but maybe they meant both ends are bad. This is fixed by just getting a new tie rod. The drag link is separate and different. How many miles on the jeep?
There is only one tie rod but maybe they meant you need to replace both ends of it. This is done by just getting a new tie rod. The drag link is separate and different. How many miles on the jeep?
well, that's what I know.. But he said it connects to the Pittman arm, so that's the drag link, right? It's a 2007 with 57000 miles on it (roughly).
Thanks! So do you know of a good brand? He suggested the Currie heavy steering kit. That has both "tie rods," but it's 1100 bucks.
I AM THERE4 I JEEP
What a crappy choice ... Why the hell would anybody choose synergy :D
Tip: take a close look around the double adjuster for fine metal filings/burrs.
My one complaint with the track bar .. I could see and fell many sharp edges and burrs. I removed the joint, sleeve and cleaned off the anti-sieze. Next I filed all the edges smooth and reassembled w/ anti-sieze.
Doing this will enable the adjuster to move freely.
I was more worried -with some age- rust taking over things and burrs seizing the adjuster.
Gonna have to do this. Felt some minor bind on my drag link while adjusting.
Looks like your bend is up to high at the knuckle. Loosen the bolt and straighten the joint out.
Old pic, already straightened it out after I saw the drag link thread over at JKO. :happyyes: As for the tie rod, is it possible to be completely level, or is the only way with a SS mount? Right now it's kinda of facing downward.
Discussion Starter #15
What a crappy choice ... Why the hell would anybody choose synergy :D Tip: take a close look around the double adjuster for fine metal filings/burrs. My one complaint with the track bar .. I could see and fell many sharp edges and burrs. I removed the joint, sleeve and cleaned off the anti-sieze. Next I filed all the edges smooth and reassembled w/ anti-sieze. Doing this will enable the adjuster to move freely. I was more worried -with some age- rust taking over things and burrs seizing the adjuster.
had me really worried for a second...
Discussion Starter #17
Okay. I've got the new tie rod on, but I can't get the old DL off. It's disconnected from the knuckle, but it's stuck on the pitman arm. Any ideas? I've tried a hammer, I've tried using a fork, PB blaster, and I'm out of ideas.
How come you didn't go with the Rancho Steering Stabilizer why did you go with Fox instead. Which of the 2 would be more important to upgrade the tie rod or drag link? Also how much more is the synergy tierod oppose to the oem tierod, and also drag link?
I ran the Rancho 7000 before the ATS,
Matador really turned me on to the Fox ATS. Believe me ... I was hesitant. Finally broke down and bought it. If you google Fox ATS .. You'll see Matadors and My thread on here.
Aways back I replaced my oem tie rod and drag link. Everything including new adjusters, clamps, etc cost $250 (oem)
About a year later a couple of my stock TRE's showed some play.
I would go with whatever is needed first. Run stock until there's wear/play ... Then replace.
1 - 20 of 24 Posts
