1 - 19 of 19 Posts
I've had my 98 sahara for 4 months now and it's given me 0 problems at 110k miles. I bought it completely stock and plan on starting mods soon. Lets see how you modded your green saharas!
Just put the rims and tire on last week pocket flares going on today.:thumb: she had 2"bb when she came to live with me. I just ordered a 1.25" bl with 1" motor lift should be here soon.
Mud
Mud
What size tires do you have on that bad boy? And are those the stock rims plastidipped? It looks great, I'm wondering if I want to paint my rims black, although I don't mind the stock ones.
33/12.50/15 on 8" steel rims I think the rims are Mickey thompson I bought them used, Dick Cepec tires. I'm hoping I get the chance to paint the top black later this winter, just too many irons in the fire right now.
Mud
2004 Sahara stock susp. w/ 33-12.5 Rocky Mountain AT's
I love where you put your cans!!! How are they mounted? Into the body?
They are mounted to the body. I drilled 3/8" holes on the cans and then bolted the bolts to the cans. Applied chalk to the bolt ends and placed on the body. Removed and had the template holes for the cans. drilled holes on body. added an extra nut and washers to the bolts for space to open the cans. then i mounted the cans to the body. list per can for mounting to body is:
30 cal ammo can- makes streamline with body.
three 3/8 bolts 3/8x16-2inch long
six 3/8 nuts-three for securing to can (acts as spacer) and three to secure to body
three regular washers and three body washers
black silicone:beerme:
They are mounted to the body. I drilled 3/8" holes on the cans and then bolted the bolts to the cans. Applied chalk to the bolt ends and placed on the body. Removed and had the template holes for the cans. drilled holes on body. added an extra nut and washers to the bolts for space to open the cans. then i mounted the cans to the body. list per can for mounting to body is: 30 cal ammo can- makes streamline with body. three 3/8 bolts 3/8x16-2inch long six 3/8 nuts-three for securing to can (acts as spacer) and three to secure to body three regular washers and three body washers black silicone:beerme:
That is by far the best idea I ran across!!!
I'll post picture when I'm done :cheers:
Thanks and forgot to mention that make sure to stay in front of the body line-(line between the fender and the cab) it just makes it easy to mount the can to the fender. enjoy...
1 - 19 of 19 Posts
