If you're planning on replacing (or removing for any reason) your hood latches, be very careful pulling the old ones off. If you happen to catch the hole with the bolt threads as you remove them, it's VERY easy to chip the paint. Right down to the metal. Easy enough to touch up, and it's under the latch itself, but I was shocked how easily the paint flaked off (and a fair bit, at that).
